How do i control the Amira via Wifi. I can connect the camera but which tool do i need to control it ?
WiFi Amira
Once you are connected to the camera's wifi network open a web browser and enter the URL amira-xxxxx.local where xxxxx is your camera's serial number.
The same procedure can be done when connecting to the camera using the ethernet cable.
Note that if you are using windows this address will only resolve if you have the Bonjour service available. This is automatically installed if you install apple's iTunes software for example. If you do not have Bonjour you can also choose to enter the camera's IP address in the URL field to connect. The IP address can be found under INFO>Network info.
Silvan Liu
ARRI Service - Burbank, California
