I'm having an issue with the WCU-4 not recognizing that I have multiple cforce mini motors hooked up to the UMC-4 (or Alexa mini). When I boot up the system I'm prompted to calibrate both motors, however only the focus motor will calibrate completely - whichever motor I have assigned to Iris or Zoom (doesn't matter which one) flashes after calibration, which from the manual indicates that "Motor is calibrated, but no motor master available (idle)".
I have both daisy chained together, and have even tried adding the LBUS to DTAP power cable (for the cforce plus motor) to provide extra power. When I look on the WCU-4 screen it doesn't even give the option to select the second motor (iris or zoom) to calibrate it.
What is going wrong that the one motor is staying idle?
Page 1 of 1
Re: WCU-4 not recognizing 2+ cforce mini motors
sorry for my late reply.
Which torque is set on the motors?
What is shown int the bottom line on the homescreen of the WCU-4 (which sign is next to Focus/Iris/Zoom)?
Which firmware is installed on WCU-4 and UMC-4?
Have you tried also to update the motors?
Best regards
Gernot
Best regards
Gernot
- Gernot Füllsack
Hi Gernot,
The torque on each motor is 4 (for the cforce plus) and 2 (for the mini).
At the bottom line it just says "Idle" on each motor.
Firmware for the UMC-4 is 1.42
Firmware for the WCU-4 is 31.15
I'm not sure how to update the motors.
I've actually successfully booted up everything with the UMC-4 and the Mini.
Lastly I can't seem to get the Hardwired mode to work with the motors and the WCU-4. When they are connected (dtap to lbus power, lbus to lcs to the WCU-4) I don't have motor control and the screen on the WCU shows "hardwire" with a spinning ring of dots, like it's trying to load something.
- vownyx
first, please always set the torque of the CForce Mini Motors to 4 (with torque 1 and 2 the Motor has not enough power).
To can update the Motors with the UMC-4, but also with the Alexa Mini. -> Explained in the Manual.
About your problems to connect the WCU-4 to the Motors:
the WCU-4 is not a motorcontroller.
You need a UMC-4, a AMC-1 or the Alexa Mini to move the motors.
It is not possible to control the Motors only with the WCU-4!
best regards
Gernot
best regards
Gernot
- Gernot Füllsack
I think I had the same problem and solved it connecting the D-tap to Lbus cable in order to apply some power to the system.
Best Regards
Best Regards
- Saul Oliveira
Page 1 of 1
