New arri motors with receiver
Wed Apr 11, 2018 3:04 am
Will these be able to be used with wcu-4 and provide lens mapping
jakecamera
Re: New arri motors with receiver
Wed Apr 11, 2018 9:14 am
yes, you can use it with white radio handunits.
With WCU-4 you can create a LDA file and send it to the RF motor to use it.
Best regards
Gernot
Gernot Füllsack
Mon May 28, 2018 9:14 pm
Does it need the lbus port on the pl mount to use mapping? What I'm getting at is if I'm using the ef mount, wcu-4 and these new motors can I use lens mapping on EF mount lenses that have hard stops?
With Alexa mini
Thank you
jakecamera
Tue May 29, 2018 8:08 am
you don´t need the lbus port on the pl mount.
The CForce Mini RF is a combination of CForce Mini and motorcontroller (AMC).
It is not possible to get lens informations direct from the lens to the Motor.
If your EF lens have hard endstops you can create a LDA file and send it to the CForce Mini RF to use it.
for more informations you can also contact as at: service@arri.at
Best regards
Gernot
Gernot Füllsack
Wed May 30, 2018 2:26 am
With this setup I would NOT have camera control correct? Playback, white balance etc...
jakecamera
Wed May 30, 2018 11:00 am
in the first released firmware it is not possible to have the camera control.
But, here is a small "spoiler": with the next Firmware it will be possible to change settings on the camera. ;)
best regards
Gernot
Gernot Füllsack
Wed May 30, 2018 3:44 pm
Excellent news, thanks.
Any ROUGH idea on timeframe for this? Sometime in 2018?
jakecamera
Return to ECS
