Input LDA from WCU-4 handset, not EVF.
Sat Nov 17, 2018 1:16 am
I am using a WCU-4 and Alexa Mini.
The handset can do most things, but one obvious one i cannot seem to figure out is that i cannot select an LDA from the WCU-4 handset, it has to be done in the EVF of the Alexa Mini.
I often take the EVF off the camera when building for Steadicam or Crane, and it is a pain that the only workaround for this is having to use a phone to programme the LDA in when not using the EVF. Am i missing something?
Surely it would be quite easy in the future to be able to select the lens directly from the WCU-4 handset via a firmware update?
Thanks
MW1stAC
Re: Input LDA from WCU-4 handset, not EVF.
Fri Nov 23, 2018 5:30 pm
If you have the files in the WCU-4 you can absolutely send to camera wirelessly. You simply select the one you want and hit the "send to camera" button.
jakecamera
Thu Nov 29, 2018 6:05 pm
Yes, but I think the question is can you change the lens file used as you change a lens on the camera without needing the EVF or WiFi? Would be great if you could.
benlangley
Tue Dec 04, 2018 9:22 am
i forwarded your question to the productmanager.
Thank you for your Input.
best regards
Gernot
Gernot Füllsack
Return to Lens Data
