Skypanel Frequency
DTLighting
Is there any printed information about the ‘frequencies’ the skypanel runs at.
The pwm frequency menu only displays:
Frequency 1
Frequency 2.....
Is there a manual describing what pwm frequencies are used
Cheers
DT
Patrick Schulze
We do not publish the actual frequencies, but by selecting one of the preset options, you should find one that would alleviate any issues you may have. The default is the highest frequency in this range. Frequency 10 is the lowest. You should be able to shoot up to 200fps natively. Always best to do a camera test over 200fps. If you are shooting high-speed, we have a High-Speed mode, which will not allow dimming (but at that rate of shutter speed, you likely need all the output you can get).
Note that "Stage Mode" is NOT recommended for image capture, as it is not optimized for this purpose and you may experience "flicker" in the image.
