Mode 6 and Calibrated
Sat May 06, 2017 9:57 am
Hi
So as I understand it , if I set the fixture to calibrated color in the light control section of the fixture menu then set the lamp to Mode 6 , then the gel to rgb conversion sheet will be correct.
Is that correct ??
Thanks
Mikey
mikeyray
Re: Mode 6 and Calibrated
Fri May 19, 2017 4:09 pm
Hello ??
Any answer please a simple yes or no will be fine
Mikey
mikeyray
Mon May 22, 2017 12:09 am
Hi Mikey,
Sorry - I missed this questions somehow. The answer to your question is yes. If you use the RGBW faders in Mode 6 with RGBW Calibarated Color Mode (in the light control menu) turned on - the gel conversion sheet will work correctly. Thanks and let us know if you have more questions.
- Mike Wagner
Mike Wagner
Return to LED fixtures
