High Speed Mode Alexa Classic
Dear Cherubim,
if the license is there (MENU > SYSTEM > FIRMWARE > Licenses Features) you shoud be able to go FPS > HIGHSPEED and boot the camera into HS-Mode.
If not, please get in touch with ARRI Service and let them have a look at your issue.
Kind regards,
Kind regards,
Also make sure you use 64GB SXS cards (not 32GB), and set the internal recording resolution to HD, (not 2K.)
Anders Holck DFF
Instagram/Facebook: andersholck
info@andersholck.com
+4526799726
+4526799726
Yes, right! Or if you need more capacity you can use SxS Pro+ up to 256GB.
https://www.arri.com/en/camera-systems/ ... K2.0014951
Is it ok to use SxS Pro, is it still full of such features?Jan Heugel wrote: Fri Feb 03, 2023 11:11 am Yes, right! Or if you need more capacity you can use SxS Pro+ up to 256GB.
Please note that the 256 GB SxS PRO+ cards are not supported by the ALEXA Classic.
Go here https://www.arri.com/en/camera-systems/ ... ding-media or search for ARRI Supported Recording Media.
Oliver Temmler
Product Manager Storage Media
ARRI Munich
ARRI Munich
