When I turn on my Alexa Classic the side screen is completely white. The functioning of the camera seems normal except for this fault. I can use the buttons on the side to change frame rate (confirmed while using the EVF) and I can change other settings using the EVF buttons and also record and play back. SDI output to a monitor also works.
I had just formatted a SXS card and then gone into the menu when the side display froze/crashed. Upon restarting the camera the screen is now always white.
Appreciate any help.
Thanks,
Robert Paterson.
White screen on side display on start up on Alexa Classic
Dear Robert,
please get in touch with your nearest service station on this matter. https://www.arri.com/en/technical-servi ... -locations
Thanks Andreas, I will do that.
Have you, or anyone else, ever encountered this situation before however? I'm wondering if this is a hardware issue or if I could just do a factory reset on the camera to solve it.
Dear Robert,
I am pretty sure this is a hardware issue.
