My arri mini lf is experiencing an unstable issue
The error code is a serious system malfunction. Please restart the camera (# 5). The image sensor is incorrect. Please restart the camera (# 41). This error code is the information I saw in the control panel on the web through WiFi,
This machine cannot be turned on and off continuously, and it takes about 7 minutes since the last shutdown to start up normally. If continuous power on and off operations are performed, the system cannot be accessed on the second power on, but it can be connected and error messages can be viewed through WiFi.
请求帮助 谢谢
ADMIN EDIT - adding the link from your other posting:
You can view specific problem demonstrations through the YouTube link
error system (#5) and (#41)
Dear luotianyu ,
please get in touch with your nearest service station: https://www.arri.com/en/technical-servi ... -locations. Via the webremote, please export the camera logfiles and send it to them.
Best regards.
Best regards.
