Is it possible to connect ZMU-3(a) to WCU-4 via LCS cable for wireless zoom control? because WZE-3 is already discontinued.
All I can recall is that the function would be implemented through a future FW update.
will appreciate your support.
Rakesh
LCS connection between ZMU-3a to WCU-4
Hi Rakesh,
From the WCU-4 SUP 3.0 Release Notes;
"Support for external zoom controls
Master Grip Rocker, ZMU-3A and cmotion pan-bar zoom are now supported hardwired to the LCS interface of the
WCU-4."
You can download the latest SUP here; Product page
Igor
WCU-4."
Igor
Dear Rakesh,
there's a 0.8m, 10m or 30m for ZMU-3A to LCS.
See here: http://www.arri.com/?eID=registration&file_uid=12603
Hello all!
I'm having trouble hardwiring my pan-bar zoom to the WCU-4
I have from the Zoom: 1' Lbus 4pin male to 5pin LCS female adapter. Then a 14' LCS cable male to male cable to the WCU-4
The pan-bar zoom is not lighting up, and the WCU-4 does not detect it in any way. I tried connecting it to the AMC-1 via LCS as well, wondering if voltage could have been an issue. But the pan-bar zoom still does not power on.
HOWEVER, if I use the same 4pin Lbus to 5pin LCS adapter, run the 14' LCS to another 5pin LCS to 4pin adapter, and connect direct to a Cforce motor, it powers on and works flawlessly. The system recognizes it and I'm able to assign it to the designated zoom motor along the daisy chain.
I'm using the AMC-1 at home at the moment, and I've also tried at a rental house to test with directly linking to the Alexa Mini. Exact same results either way. I can use the same LCS cable to hardwire the WCU to the AMC-1, so it appears all the cables are in working order.
Is there a setting I'm missing in WCU that activates the power output and interface of the LCS port?
Hello JonBowerbank,
it can be that the 3.3 Volt switching Regulators is defect in your pan-bar zoom.
Please contact cmotion for further informations: support@cmotion.eu
best regards
Gernot
best regards
Gernot
Thank you Gernot!
The pan bar zoom is actually a loaner from a vendor until my own is in stock and gets shipped to me. I'll let the vendor know, hopefully it's just that.
I tested with another Pan Bar Zoom unit, and same results.
Only thing I can think of is either it's an issue with the power output of the WCU-4 hand unit, or possibly I need a shorter cable with more robust housing to preserve such a low voltage?
Has there been any update on this? I want to purchase a separate zoom control to hardwire to my hand unit so that I can hand the operator zoom control during Russian arm, crane, or SteadiCam setups. Specifically, does anybody know if I can use the panbar zoom for this purpose since the ZMU-3a is no longer available? I had imagined exactly the setup JonBowerbank has posted above.
My issue ended up being a bad electronic voltage switch at the LCS port of my WCU-4
It was repaired, thanks to Camadeus.
Been working flawless ever since!
