WCU-4 & SONY Venice
Locked
saavedrarolan
Hi, I´m working with SONY Venice cameras and the WCU4 + AMC1 and was wondering if there´s any way we could record remotely from the hand unit.
The rental house that is providing us the equipment says it doesn´t exist yet any cable that can connect the motor control unit and the camera. Is this true?
Even if it didn´t exist one in your catalogue, it could be possible to make one to connect the camera (24V OUT connector (DC OUT 24 V, Fischer3-pin) or AUX connector (LEMO 5-pin) ) to the motor control unit (CAM Connector 10-pin)?
You can work with out this feature but is a pain in the neck.
Thanks a lot!
Daniel.
Hei Daniel,
I've had a chat with our ECS Team: ... since it's "all Sony", you can use Cable CAM (10p) - Sony F5/55 (K2.0001997)
or the Cable CAM (10p) - RS (3p) (K2.0001606) for start/stop.
Florina Steiner
we have at the Filmakademie 2 Sony Venice with the Start& Stop Kable for the WCU-4 and the RF Motor. The only question what I have so far is: Why is there not any red light on the WCU-4 if I trigger the Rec Button with the Hand Unit? I only see the Rec button on the Camera.
Thank you
Dear Florina,
which SUP version is installed on your WCU-4?
Edit: also: which one is on the cforce RF.
nageskeshudas
Jan Heugel wrote: Wed Oct 31, 2018 11:25 am Hei Daniel,
Hello Jan,
(K2.0001606 is the same cable which we are using with Cmotion Compact One camin?
Nages Keshudas
M/s Ultra Cine Vision
Locked
