Hi
About every 3 or 4 power cycles, my Mini LF hangs on start up. It displays a color chart in the view finder and the power button flashes. After a restart by holding power button for 5 sec. the camera powers on as normal. I have the latest firmware installed.
Any thoughts.
Thanks in advance
Taylor
Mini LF boot up failing
I have had this issue also. I think it's only happened to me when there has been a card in the camera. Did you have a card in the camera when you booted, and also, did you by any chance have media on the card that was at a different sensor resolution to the one you were using when you booted the camera?
Thanks for the reply. This happens to me during the course of a day when we need to change batteries, lunch break etc. Same card same project settings. Happens on batteries and/or power supply. I'm pretty sure it happens when there is no card in the camera as well. Strange as it seemed like it was not happening much for a while and now its back with regularity. It is an added stress to a shoot where not needed. Wondering if this is the time it won't boot at all. Hoping its a software fix.
Taylor
Taylor
Dear Taylor,
or everybody who experiences that issue:
In order for us to find out what causes that behaviour please create logfiles right after the issue occurrs and send them to digitalworkflow@arri.de.
You are on SUP v6.0.22, right?
Hi Jan,
I've been sending my log files to Richard Hester at Arri UK. Do you have any info on what could be causing this eg is it potentially hardware related? Having a camera that at times doesn't want to boot can be pretty stressful.
Thanks Jan
Sending files to you now
Best
Taylor
Best
Taylor
any update about this? im getting this problem right now ukuran kertas a4
Hi Everyone,
I am observing this issue as of now, and is there any work around or fix so far figured out? Existing users who observed this issue how you guys managed to resolve the issue?
Please kindly provide your valuable input to handle this situation. i know need to send it to ARRI service, before that i wanted to understand is tere any work around to manage current shoot.
Dear sathiyam144,
please get in touch with ARRI Service, as this issue might have different causes.
Send them your serial number and logfiles and see what they're saying. (=free pre-diagnostics
- Location: https://mini-militia.com/mini-militia-for-pc/
I hope you will get update soon by the devs, and I also posted a thread about Alexa mini and I hope I will get response's so soon from the community.rizarefaldi wrote: Mon May 03, 2021 8:53 pm any update about this? im getting this problem right now
ADMIN EDIT: I doubt you haveing any problems since you added a spam link in you post; deleted.
Keidrych Wasley wrote: Tue Mar 02, 2021 1:32 am I have had this issue also. I think it's only happened to me when there has been a card in the camera. Did you have a card in the camera when you booted, and also, did you by any chance have media on the card that was at a different sensor resolution to the one you were using when you booted the camera?
For me it was exactly the same, but the problem resolved by itself.
did you find a solution to this problem?Taylor at Regent wrote: Mon Mar 01, 2021 3:08 am Hi
Any thoughts.
Thanks in advance
Taylor
it hard to say, but still we didn't find any solution to fix mini LF boot up failing.Davidjoy wrote: Wed Jan 18, 2023 7:16 amdid you find a solution to this problem?Taylor at Regent wrote: Mon Mar 01, 2021 3:08 am Hi
About every 3 or 4 power cycles, my Mini LF hangs on start up. It displays a color chart in the view finder and the power button flashes. After a restart by holding power button for 5 sec. the camera powers on as normal. I have the latest firmware installed.battle royale shooter for ios
Any thoughts.
Thanks in advance
Taylor
