I seem to have a strong signal from the mini lf wifi antenna, full bars in the Mac menu and it reports connected.
but when I load the camera menu in a browser its very inconsistent. on iOS it doesn't even load at all. on chrome it occasionally loads and mostly gives this error "Waiting for data from camera..." I can't tell if there's any specific circumstances in which the page actually loads, it seems to be random.
I'm also trying to connect to the camera with Livegrade and having problems with it disconnecting, which seems to be related to this mobile browser connection issue- although the computer is connected to the cameras wifi network - something is not communicating properly between the two which breaks the connection in the browser and in Livegrade as well...
any ideas what could be wrong here?
Dear Max,
are you on Mini LF or Mini?
Which wireless mode are you using?
iOSs not loading at all is strange...
Did you test a wire-connection to make shure the cameras' webserver is working properly (also to rule out your computer)?
Try to do a factory reset, resetup your wireless and give it an other try.
Perhaps change the default password.
Thanks Jan,
Mini LF
Host Mode
I'll try the wire and factory reset next job and update you
all the best,
Max
Mini LF
Host Mode
all the best,
Max
For client mode a colleague suggested to make shure your Wifi has WPA-2 and encryption is off.
But the wireless network is there an you can log onto it...
Please keep us posted.
