UMC-4 LiveLink Streaming
Locked
norbert.kottmann
Hi
We try to connect our UMC-4 with the Urneal Engine, but we do not get a connection with LiveLink.
We can access UMC-4 on its IP address on the Unreal PC via Webbrowser as described in the manual. But if we add it in Unreal as a Message Source it does not send any data.
We think the problem is, that we can not set any streaming options in the UMC-4 System > Network Setting. The is no Streaming option as in the manual mentioned (where to choose unicast/multicast and endpoint).
What are we doing wrong?
Using Third Party Camera with SXU-1 and necessary additional D-Tap/LCS/LBUS cables. Firmware is 2.1, Unreal Engine 5.1 with corresponding ARRI Plugin.
Thanks for your tipps.
Norbert
Andreas Oestreich
you probably have missed the fact that you need to download a new Firmware for the UMC-4. This firmware can be found in the same downloaded zip file where you downloaded the Unreal Engine PlugIn:
https://www.arri.com/resource/blob/2945 ... 3-data.zip
Let me know whether this solves you issue.
Best regards
Andy
norbert.kottmann
Hi Andy
Ahhh! Thanks for the hint! Have to check it out, didn't saw that.
Would be great if ARRI can put the firmware on their download page directly or mention it at least in the Plugin manual.
Best
Norbert
ARRI-ECS-Service-Team
Hi Norbert,
here is an informative section that shows the latest versions and manuals regarding ARRI Live Link Metadata
https://www.arri.com/en/learn-help/lear ... ata-plugin
all the best,
Daniel
ASutardy
Hi all. Has anyone had luck using the current LiveLink plugin on UE 5.3?
abshiregabrielle
Hello, everyone! On UE 5.3, has anyone had any success with the LiveLink plugin that is now available?
Andreas Oestreich
the PlugIn is currently being compiled for Unreal Engine 4.27.2 - 5.3.2.
The updated PlugIn will be online in the next days.
If you need the PlugIn right away, here is a link, which is valid until end of the year:
https://webgate.io/directlink/3b940c8a9dbf6068
Best regards
Andreas Oestreich
Andreas Oestreich
Locked
