cforce mini RF changing Global Unit
Jason
Hello.
I've got a Hi-5 (SUP 2.0) connected to a force mini RF (SUP 2.0.3) and every time the RF motor is powered down it resets the Global unit on the handset to Meters.
Is there a fix for this?
I've tested it. on two different cforce mini RF motors and they both have the same issue. I've powered them from the RS power connector and the dtap/hi rose connectors on a Venice.
The lens file I'm using was created in the Hi-5 using feet as the Unit.
Thanks,
Jason
ARRI-ECS-Service-Team
Hi Jason,
thanks for your feedback, we hope to include this patch in the next cforce RF update.
As workaround you can factory reset the cforce RF motor by holding both buttons for 6 seconds until indicated on the motor display.
all the best
