we are going to shoot a project with alexa mini LF, there are some scene with old CRT monitor, we would like to film image from the old tv. in some test that we did we couldn't fix the sync between monitor and Alexa mini LF.
In other similar cases, with Alexa Plus, we fixed this using "Phase Sensor" but this function is only Plus cameras. there is some similar for Alexa Mini LF, like external sync, or other.
we are shooting at 25fps@180º and the image from the crt are a 25fps.
Thanks
Andrea Cuomo
Mini LF crt sync
Dear Andrea,
using a tri-level sync signal to synchronize both camera (via SYNC IN) and the playback device feeding the CRT monitor should work here.
