Sky panel colours not matching
Kolmikonproductions
Hey all
We’ve got 34 panels on set run through a Chamsys console. Were on firmware 4.4 stage mode and mode 6 (20ch) colour mode cct and calibrated colour is on.
We’re finding a few fixtures aren’t the same colour as all the other fixtures when dimmed.
Has anyone see this? Any tips?
Thanks
Brian Doran
You may want to check if any of the units are V1 light engines vs V2/V3. If you do have a mix, it is possible to set the V2/V3 into "LE Compensation Mode" so that they better match the V1 units. This option can be found under "Fixture settings - LE Compensation".
Brian Doran
Product Specialist, Lighting
ARRI Americas
