Alexa mini
Alexa mini with latest firmware. After enabling the recording beep in the menu there is still no audible beep. Did a factory reset and still the same. Anyone run into this issue? Anything I can try?
Dear sleuthinquire,
after a factory reset, the beeper is not enabled, you will need to do this in MENU > RECORDING > REC BEEPER/TALLY.
If this does not help, it sounds like a service case (beeper broken). Please get in touch with your nearest service station (https://www.arri.com/en/technical-servi ... al+Service), provide them with a camera logfile and give as much information as possible.
