I am working with Arri 35 files within Premiere (v24). I have followed the guidlines in creating sequnece using the RAW file and have imported the Look file for the Log4 clip using Lumetri Color. The look file doesnt have any significant impact and indeed the footage looks like Log after applying the Look file. I have also attempted to use DaVinci and I get the same result. My workaround has been to go through the ArriRefference tool and create proxies with the Look while I work on the off-line but will need to go back to the RAW for the online.
Any help would be greatly appreciated.
Thanks!
Look file not working
could you please get in touch with us via E-mail digitalworkflow@arri.de and send us the look file and 3D-LUT you're using?
Thanks.
Thanks.
Did you try adding the offical DRT 3D-LUT to you target color space in addition to the log-2-log / Creative Modification Transform (CMT) / 3D-LUT?
To get a conversion into Rec. 709 for example you have to use our offical LogC4 to Rec709 from our LogC4 LUT Package. This needs to be added in addition to the log-2-log / Creative Modification Transform (CMT) / 3D-LUT?
More information about our ARRI Look Files you will find here.
https://www.arri.com/en/learn-help/lear ... look-files
