How do you calculate the equivalent focal length for a lens on a Super 35 sensor when using other ARRI cameras, such as the Alexa Mini LF, Alexa 65, and ARRI 16SR? What are the crop factors for each of these cameras?
For example, if you use an 18mm lens on a Super 35 sensor, what would the equivalent focal length be on each of these cameras?
Relative crop factor Alexa Mini LF and others
the crop factor is defined as:
Crop Factor = Diagonal of Smaller Sensor / Diagonal of Full-Frame 35mm Reference Sensor
where
Diagonal = √(Sensor Width²+Sensor Height²)
c = √(a² + b²)
Here's a good explanation:
https://shuttermuse.com/calculate-cameras-crop-factor/
In purely mathematical terms, the following Crop Factors result:
where
c = √(a² + b²)
- 35mm Film (Reference) = 1,00
- ALEXA Mini LF = 0,967668935
- ALEXA 65 = 0,722735981
- 16SR (S16 mm) = 2,973959605
Thanks for the detailed explanation and the crop factor calculations! It's helpful to see how the equivalent focal length changes across different camera systems. The reference to the diagonal measurement formula is especially useful.Simon Duschl wrote: Tue Mar 18, 2025 2:49 pm Hi,
where
c = √(a² + b²)
Please note these values are related to the full sensor readout e.g. Open Gate or S16mm Film and not to smaller cropped sensor modes.
thanks! I was reading the website, and I think your answer is a bit different. According to the website, instead of:
It would be:
Crop Factor = Diagonal of Full-Frame 35mm Reference Sensor / Diagonal of Any Other Sensor
For example, in the website's Canon APS-C Crop Factor calculation, they show this:
Crop factor = 43.27mm (Full-frame 35mm) / 26.68mm (APS-C) = 1.621814, rounded to 1.6.
It seems that the 35mm full-frame sensor is used as the reference at the beginning.
Also, when calculating the crop factor for Super 16 (S16), if I use your formula instead of the one on the website, I get:
Crop factor = 14.54mm (S16) / 43.27mm (Full-frame 35mm) = 0.33 for Super 16, instead of the 2.97 value you provided.
Would you agree with this? Or is there something I’m missing?
It would be:
Hi Garchivo,
since in the end we're looking for a factor to multiply the focal length with to learn which lens we need for the other format...
I'd stick to the definition of the crop factor where you divide the diagonal of your reference size (e.g. 35mm) by the other sensor. So, crop factor = diagonal REF/diagonal SENSOR_A;
Picking up your example, that means:
crop factor = 43.27 (full frame) / 26.68 (aps-c) = the rounded 1.6.
So for the same field of view that you get on a aps-c 40mm lens, you need a 1.6x longer lens for full frame (64mm).
Thnaks Jan,
So, when comparing the Alexa Mini to the Alexa LF:
Crop factor = 44.7mm (diagonal of LF) ÷ 33.59mm (diagonal of Mini) ≈ 1.33
That means a 30mm lens on the Alexa Mini would give a similar field of view to a 40mm lens on the LF, right?
I found these diagonal values online, not sure if they are right.
Yes, dividing the diagonals gives you a good idea depending on the selected sensor mode its varys between 1.3-1-4ish.
