I have just realized the currect AMA Arri plugin for Avid products is not working with ALEXA Mini mxf files.
Is there anything I am missing? Is there a Beta Ama Plugin to test?
Thanks in advance,
Fer M
Hi Fer M,
did you try the latest version of the nablet ARRI AMA plugin which is available here:
https://nablet.com/arri-ama-plugin
Please select the correct "importer" -> right click in BIN -> Input -> Source Browser
In the source browser, right click your files and select "Link with..." -> nablet ARRI
Once the correct plugin is selected here it should be possible importing ALEXA Mini ARRIRAW files (and also other ARRIRAW files).
