Hot swap CF Card/Follow Record
General Discussion
Locked
benmullinkosson
Is their a way to keep recording to a second CF card once the first card fills up?
Each time I finish one card the camera beeps to signal card full, then I have to manually hit record again so I lose moments if I don't hear the beep.
Any solutions? New to the forum, thanks!
Guenter Noesner
No - there is no card spanning possible. The behavior is as expected. If you need longer running times, you have to use lager media or select a more compressed codec.
Locked
