Photometrics for M90 with 6k globe.
Locked
ms500
I'm looking for photometrics for an M90 with a 6k globe. I'm wondering if the physical size of the globe changes the way it projects in the reflector or if it's the same but 1/3 less light.
Thanks.
Andy Barnett
Dear ms500
The light centre length for the lamps is the same so the characteristics will be very similar. The lumen output is 600000 as against 875000 so just under 70% of the output.
I hope this helps.
Regards
Andy Barnett
ARRI Lighting Technical Support
Andy Barnett
Lighting Technical Support,
ARRI CT
Uxbridge
UK
ms500
Perfect!
Thanks for your time.
Locked
