Hello!
Is it possible to also desqueeze with a 1.3 factor on an Alexa Mini? I couldn't find info on that in the operations manual.
Thanks
1.3x desqueeze Alexa MIni
Page 100 of the manual says the anamorphic desqueeze has a factor of 2.0. As far as I know, that is the default and only option.
"The recording resolutions with Ana. in their name are intended for recording with
anamorphic lenses with a squeeze factor of 2.0. The respective ProRes resolutions
perform a de-squeeze on the recorded material. The respective ARRIRAW resolutions
are recorded as-is, only anamorphic de-squeeze is enabled per default on the viewing
paths."
Regards,
paths."
Regards,
