I would like to know how ARRIRAW Converter spits out the "exr/aperture" value which is not detected in the raw file in Nuke for example.
I have read the Metadata white paper and honestly the math is to complicated for me. I would like to build a tool in Nuke to auto convert the Lens Iris values in the raw metadata to an aperture value.
for example i have an ARRIRAW file loaded in ARRIRAW Converter with the following:
- Iris: 5.6+3/10
- Linear Iris: 6272
The same file in Nuke:
- arri/camera/LensIris: 6.21606
EXR converted from ARRIRAW Converter and read in Nuke:
- exr/aperture: 5.65685
- exr/com.arri.camera.LensLinearIris 6.272
I'm after the aperture value which in this case is 5.65685. How do you convert those Iris or Linear Iris to that number?
Thanks
The math behind Iris to Aperture values
Dear Mohamed,
out of "there's a hundred pages document which you should look at", this is what's relevant for you:
Regular iris values
How to calculate regular Iris values from linear iris values:
While the above code is mathematically correct, it does not match the rounding conventions established in film and photography for centuries. A tabled approach prints the more familiar values:
Here's an example list:
Regular iris values
Code: Select all
nt16 n = (LinearIris + 50) / 1000;
// now n equals the index + 1 of the correct T-stop without fraction (because n is an integer value)
// +50 is just because of rounding
n -= 1;
// subtract an offset of -1 to get the correct index
double FullAperture = exp2((double)n / 2);
// now calc 2^(n/2). n/2 has to be calculated float, result FullAperature is also floating point
To get the [1/10] of Aperture Stop out of the fraction do the following:
// get the fraction
int16 FractionAperture = (LinearIris + 50) % 1000;
// get the Aperture Tenth
int16 ApertureTenth = FractionAperture / 100;
Code: Select all
void printApertureValue(U32 apertureValue)
[i] // Standard full-stop f-number scale
// (conventional rounding of sqrt(2.0^N) N=-1,0,1,2,...,16)[/i]
double fNumberScale[18] = {0.7,1.0,1.4,2,2.8,4,5.6,8,11,16,22,32,45,64,90,128,180,256};
int linearIris = apertureValue + 50; // + 50 for rounding
int fullApertureIdx = linearIris / 1000;
int fractionAperture = linearIris % 1000;
int apertureTenth = fractionAperture / 100;
if(0 <= fullApertureIdx && fullApertureIdx < 18)
if(apertureTenth == 0)
printf("%.1f\n", fNumberScale[fullApertureIdx]);
else
printf("%.1f + %d/10\n", fNumberScale[fullApertureIdx], apertureTenth);
else
printf("out of bounds\n");
Hey Jan
Thanks. But the code posted above is exactly what I don't understand. How exactly do you do this on a calculator for instance?
This seems like code you have to do in some keda be of software?
Cheers
Cheers
Hi Arri Team,
So if my LensIris is set to: 2.0 +3/10, what would be the tcl formula to add to a Text node in Nuke?
Could you shed some light please?
Thanks
Thanks
Hi
@fpalomares
Why would you reverse this into the LDS-encoder's value?
@Mohamed,
yep that's the code I got for Nuke.
@fpalomares
@Mohamed,
