WCU-4 Manual T-stop information input
Nick Forster
Would it be possible to manually input t-stop into the WCU-4 handset without having to use a motor or Lens data encoder? It's really helpful to have the depth of field read out on the handset but I don't want to have to buy a lens data encoder and add more bits to the camera.
Nick
xanoramix
I would love that feature....
Alexandre Valentim
Focus Puller - Portugal
Gernot Füllsack
if you use LDS lenses, you get the informations on the WCU-4 without Motor or lens data encoder.
When you use LDA files, you need the magnetic encoder values from the Motors or LDE-1 to get the scale informations/position of the lens.
best regards
Gernot
nzben
Hi Gernot,
I know its a different system, but it works on a Preston. When you select a lens (essentially the same as a LDA file) and if you have programmed the iris, but don't have the iris motor connected, the iris data still comes through relative to the position of the slider control on the handset. This way if you match the iris position on the handset to what the DOP has set on the lens then the DOF readings work with the Light Ranger system. Very handy and it would be nice if the same thing could with with the Arri system.
Regards,
Ben R
Dear Ben,
well, that's possible because Preston doesn't make cameras... they only have so much sorces to gather the data.
For us this system is not precise enough: imagine you would set a value on the hand unit (f5.6) but have a lens set to f2.8.
f5.6, the inaccurate value, would be fed into the metadata. LDS is camera-centric, the values al origin within the LDS core in the camera or UMC unit.
nzben
I understand that Jan.
In this case I'm looking at it from the perspective as a tool for the AC. If there is an iris motor on the camera or the lens is LDS, then I get the information I need. If there isn't an iris motor on the camera (in the case of non-LDS lenses), then there obviously isn't a desire on the production for the metadata for that lens axis to be captured and used, but it would still be useful to me on set.
In my experience even when the LDS or LDA data is captured in most cases it isn't used by post production - surprisingly even on large VFX driven projects.
BR
Hey Ben,
if there's no motor and no LDS, there's a gap to bridge - that is why we invented the Lens Data Encoder (a motor-like thing, without any drive).
If the lens data is not used - well that is because of inexperience with the workflow I guess.
Because if you've set up your part correctly (what one can assume since you are interested in accurate data on the WCU-4) - it is all there - automatically in every file recorded.
Postproduction only needs to extract the data.
Do you know why they don't use the data?
I would like to encourage you to spread the word: prodcutions don't need to take money in their hands to make use of that data.
A further read here: LDS FAQ
nzben
Jan, PM me if you want.
jakecamera
I'll jump in on this with a resounding YES PLEASE! We all know how the systems work. But we would like the ability to manually set the iris info on the wcu-4 using ANY lens and have the depth of field readout occur just like if the iris motor was on and was mapped. Possible or not?
I don't think you'd find an ac working who thinks this is this is a bad idea. Quite the contrary.
The argument about the post metadata being wrong if the iris is actually set differently by accident is only valid in a small percentage of overall production, simply because most don't use it, and that's operator error if it's set differently anyway, just like anything else. So there is theory and reality. There is a TON of day in and out use where only one motor is used, and this would be an amazing feature.
JonBowerbank
What would be great, but probably not possible, would be a motor setting to switch an Iris motor between Servo & Manual.
BUT
I suppose you could always mount an Iris motor, calibrate it to the iris. THEN disengage it from the barrel so the motor's gear spins freely when you use the slider. This way your DP is free to adjust stop, and you can just match it on your slider for your DoF readout.
1stACLG
Just wanted to comment that I, too, would find it hugely helpful if I could manually enter the T-stop in the WCU-4. We rarely have a need to even bring the iris motor to set. So I never get to see the Depth of Field on my handset, which is really a shame for such a pricey unit.
Anyway, if there could be an update that allows the T-stop to be entered on the WCU-4 with no iris motor at all, it would be very appreciated.
mathew423
Jan Heugel wrote: Fri Mar 02, 2018 10:35 am Hey Ben,
Thank you, I understand more about LDS
