Hello
Just saw the announcement of the new Cforce Mini RF motor and i was wondering if it is compatible with previous hand units from Arri, WCU-3, WFU-1?
LDA and LDS don't apply here right? We have to map them?
Regards
new Cforce Mini RF
yes, the new motors with radio are compatible with older white radio handunits.
You can create a LDA file with WCU-4 and send it to the Cforce RF motor.
There is no LDA archive in the motor, so you can only use the LDA you have send last.
LDS is not possible, because the motor get no informations from the lens.
Best regards
Gernot
Best regards
Gernot
Considering buying a Cforce Mini RF and I have a couple more questions:
- Let say I have wcu-4 + 1x cForce Mini RF + 1x cForce mini with Alexa Mini camera and a LDS prime lens. I would like to have lens info on camera and hand unit. Because LDS can´t be sent back to hand unit with cForce Mini RF, can it be used just as a "dumb" motor?
- With any Alexa camera + cForce Mini RF + WCU-4 hand unit combo, LDA lens files will be available on metadata?
- With Alexa Mini + cForce Mini RF, camera control features are they all available?
- cForce Mini RF works with UDM-1/ Cinetape/ Focus Bug? Tracking functions also works?
- Cmotion Cvolutiuon white radio works with Force Mini RF? As main or second hand uni assign?
Thanks
Alexandre Valentim
Thanks
Alexandre Valentim
Alexandre Valentim
Focus Puller - Portugal
Regards,
- Yes, it can. The radio can be turned off and the unit will function as a normal Cforce motor.xanoramix wrote:Considering buying a Cforce Mini RF and I have a couple more questions:
- Yesxanoramix wrote: - With any Alexa camera + cForce Mini RF + WCU-4 hand unit combo, LDA lens files will be available on metadata?
-If you use the radio in the motor then camera RUN/STOP function, tally and camera status information are available if you use a Cam to EXT cable.xanoramix wrote: - With Alexa Mini + cForce Mini RF, camera control features are they all available?
- Not sure, I'll have to leave this for someone else to answerxanoramix wrote: - cForce Mini RF works with UDM-1/ Cinetape/ Focus Bug? Tracking functions also works?
- Yes. Compatibility can be seen here; https://cmotion.eu/page/cvolutionxanoramix wrote: - Cmotion Cvolutiuon white radio works with Force Mini RF? As main or second hand uni assign?
Regards,
Thanks for the info.
One more doubt:
One more doubt:
- and what about all other camera control menus and user buttons that are usually available on WCU-4? Do they also work with Cforce Mini RF motif?- With Alexa Mini + cForce Mini RF, camera control features are they all available?
Alexandre Valentim
Why would you use cforce mini RF with Mini at all and not use the internal function from Mini?xanoramix wrote: - and what about all other camera control menus and user buttons that are usually available on WCU-4? Do they also work with Cforce Mini RF motif?
Alexa Mini antenna range is poor, i guess bypassing that with Rf motor should have better range and stable signal.Why would you use cforce mini RF with Mini at all and not use the internal function from Mini?
Alexandre Valentim
That might be true for very early models of ALEXA Mini, but production models have the same specs in regards to radio coverage than cforce rf. Truth to be told, cforce rf uses a newer transceiver module but range characteristics are similar.
jan
jan
Has any of you got the answer about earlier question below?
and when using Cforce mini RF with Amira (via CAM to EXT 6-pin) or Alexa Classics (via CAM to EXT 16-pin)? Can I use the remote license feature on WCU-4?
Rakesh
Rakesh
