De Squeeze Output on Anamorphic
lifescapes
Hi guys,
We are doing a test on Alexa LF. We paired with it a Master Anamorphic 35 (2x)
Sensor: OpenGate
Frame Line: Arri 2.39 (ratio: 1:29)
I can monitor correctly - however the the video is squeezed., frame guide is normal. When i do change the squeeze setting on the output to 2.0 the image is now correct however the frame guide suddenly sort of becomes 1:4 ratio. The image has become wider. It's as if we cannot trust the frame guide anymore.
Any insights?
thanks alot.
Hi there,
can you post your frameline or did you choose an internal one?
