As per documentation the Arri Look library is available within the Camera with three strength intensities per preset/look.
http://www.arri.com/camera/amira/learn/ ... brary_faq/
What is the ARRI Look Library?
The ARRI Look Library is a collection of 87 looks in 3 intensities for use in ARRI cameras with advanced look management (ALF Support).
Can you please describe how the intensity settings should be interpreted in post finishing packages like Resolve and Baselight?
For example is it via a bland function of the interpreted LUT whereby 3 equals 100% and 1 equals 33 percent LUT blend?
Many thanks,
Adrian
Arri Look Library - Intensity Setting interpretation in Post
Dear Adrian,
there's no need for this, these are separate LUTs. You always want to "blend" 100%.
