Hello everyone:
I have seen that the Cforce Plus motor can be mounted on rods with 2 options different than the regular clamp console, that is:
1. CLM-4 Rod-to-Rod Adapter 15mm, K2.72106.0
2. CLM-4 Rosette Adapter for Hill Bracket, K2.72113.0
Let´s see if I got this right:
1. Can I use this to mount with a Preston motor arm?
2. Can I use this to mount with an arm from Jerry Hill?
Is that correct, have you successfully mount the force Plus with Preston and Hill´s arms?
Best Regards to everyone.
Saul Oliveira
First AC
Spain
cforce Plus motor mounting options
Yes, you can use the Hill Brackets.
Regards,
Hendrik
Regards,
Hendrik
