Unusual image corner beahviour.
davidnavarro
During a shoot today I started experiencing a strange corner flare/smear effect. There is even a vertical line that separates that creates a change in exposure.
I tested it with a few lenses and even with different mounts (ef and pl)
and found roughly the same behaviour
this is with a mattebox on.
anyone has any idea what this is?
https://vimeo.com/manage/videos/8122455 ... =119184067
davidnavarro
upon further investigation I found this behaviour in all corners.
I also notice a quite shiny area inside the mount and I am started to suspect that this could be the cause
Dear David,
Which lens did you use in your tests on the Mini?
Thanks,
