Hi 5 smart rings and Alexa 35
bain99
I’m having an issue with smart rings on a Hi 5 unit where I’ve programmed /mapped the lenses in the hand unit and everything works with the blank smart ring, but when I switch to any of the pre-marked smart rings, the motor throws the lens to infinity and locks. Once the blank ring is replaced, the problem goes away. I re-mapped a lens with a pre-marked ring installed and it works with that ring but the marks do not align. Using w/ Alexa 35 camera and Atlas Orion lenses.
africanahull
Make sure the lens you are mapping precisely corresponds to the smart ring's stored focal length. Small differences can become problematic.
Try installing a pre-marked ring and precisely recalibrating the lens motor positions. There could be a small difference in the blanks' calibration.
